Home > Help Needed / General Tech Chat > engine steady wood&pickett
paneermeel
Member #: 1404
The Netherlands
anyone used it on his engine?
It seems to me that it gives a cleaner look in the engine bay:)
But is it any good?
Edited by paneermeel on 16th Mar, 2008.
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
graemec
Member #: 1424
Carnforth, Lancs
I have used them and find them good. Although if you use a bypass hose things get a little tight. Don't get in the way as much though.
Their design flaw is that the bolts are only in single shear but if your standard steady is good this shouldn't be a concern.
If you buy one I suggest adding a little bit of mig to where the captive nut is on the water pump bracket - one of mine came free very easily.
Also available from Avonbar (in fact I think they are an Avonbar product).
Edited by graemec on 17th Mar, 2008.
look lighter also!
my extra steady weighs a ton!
paneermeel
Member #: 1404
The Netherlands
The one from Avonbar is also adjustible :cool:
www.turbomini.nl
El Potter
Member #: 2169
Malta (Ex. Scotland)
What if it moves though?
Won't it ruin the waterpump seal and result in a leak?
Or does it fit on the outside?
Warning:Stig in Training
graemec
Member #: 1424
Carnforth, Lancs
The one in the picture is adjustable too isn't it?
It goes on the outside of the water pump using two of the pump bolts. The plate is quite thick (6mm) so if the the beginning of the threaded holes for these bolts is a bit suspect it is also worth trying to source some slightly longer.
paneermeel
Member #: 1404
The Netherlands
i looked again and youre right.
I don't believe it will any different , Avonbar or W&P.
But i like the idea of it being adjustable. I'm going the Mirage route and some extra space is always good:)
www.turbomini.nl
El Potter
Member #: 2169
God I'm such an idiot sometimes!!!But whats wrong with the ultimate engine steady?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
You need the steady on the clutch side to be adjustable too though, the bottom one on the gearbox is slotted so that should be OK.
On 7th Nov, 2008 Nic said:
naeJ
m
paneermeel
Member #: 1404
The Netherlands
@ El potter: a cleaner looking engine bay and no drilling in the bulkhead *happy*
Looking at the avonbar site i see that the one pictured above is part number ABR024
Is the one on the clutch side part number ABR024/A??? i think. :-
There's no picture and i'm not 100% sure......
www.turbomini.nl
Try fitting one to a twin cam head!
