Home > Help Needed / General Tech Chat > vented disc set up
adam1330
Member #: 238
essex
just wanted to know if its o.k to grind the lugs off the drive flanges, or should they be properly machined?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Heres a pic of mine if it helps.
jamesfawcett
Member #: 218
by the way, that was when i got my mini, all that rust isnt there anymore *happy*
Neither was that thing, if you want to call it a shocker.
Nick
Member #: 154
Midlands
its best to machine them off, you get it level all the way across then. if you grind it you may get the wheels sitting unevenly or wobble and stuff.
dan
Member #: 93
yeah i got mine turned off when i was getting the discs turned down in diameter, managed to get it all done for ?20
