| Home > Help Needed / General Tech Chat > megajolt on n/a | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
20th Mar, 2008 at 04:35:59pm
hey chaps im going to be taking my turbo off soon for a rebuild and still need to use the car.
'always keep a spare shot for a stray bird' |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
20th Mar, 2008 at 05:13:48pm
Would recomend programming a map similar to a std dizzys advance curve/
20th Mar, 2008 at 06:34:04pm
here ia a map from my old 998 NA. ignore the 14s they were an attempt at a tickover cure, replace with something a bit higher.
Edited by wil_h on 20th Mar, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Mar, 2008 at 07:35:24pm
thanks chaps thats a huge help will 'always keep a spare shot for a stray bird' |
20th Mar, 2008 at 07:38:42pm
On top of what Wil's posted up might want to drop the top left value down to 5 or 10 degrees as that's what's used when starting. Isambard Kingdom Brunel said:
20th Mar, 2008 at 08:05:56pm
If it's MS, it knows when it's cranking and uses the standard 10 deg of the EDIS. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
21st Mar, 2008 at 02:22:44am
ahhhhhh now i know why when i had that map in my mini it ran like poo when i pulled away!! |
