Home > Help Needed / General Tech Chat > pots two and three not firing ?
Richie
Member #: 628
anyone had issues with the two middle pots not fiing ? Jordie has been having issues with his motor ? also it seems to be going through BK450 head gaskets like confetti ?
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
RICHI is it turbo ?
if so i suspect the CR ratio is too high for the boost hhe is using...... det taking the weakist link out *frown*
been there buddy, also check the head and block faces for flatness
you have got to sort the issue of the det out
oh ! just one thing is the torque wrench up to it ?????
cracking off on earlier ???
no comments Please Nic *laughing*
JordieNE
Member #: 1591
Prudhoe, Newcastle
std 4psi boost
head checked and skimmed 12thou to make it flat when the 1st headgasket went.
Done it with 2 good working torque wrenches.
Am getting another engine, so bugger it. will flog it on once ive decided which has the best turbo etc.
JordieNE
Member #: 1591
Prudhoe, Newcastle
Pot 1 (radiator end) reads 13bar compression
Pot 2 = 8bar
3 = 12bar
4 = 13bar
Pot 2 went upto 10 when we put a drop of oil in it.
rings goosed as well
engine too lean aiding det is my thoughts
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
When/ where did you get the engine setup?
Alex
AlexF
Richie
Member #: 628
he didnt get the chance to. it was popped in, new head gasket, and then taken for a beast around the industrial estate. i beleive he setup the fuel mixture himself with some of the lads from the club.
here is the build thread. (Jordie you should have put it on here too *wink* ) there is a video of his project in action, this was a very very quick turn around bearing in mind the bodywork that was needed, and its his first stab at forced induction.
http://www.tynemouthminiclub.co.uk/forum/v...1&thread_id=734
http://www.tynemouthminiclub.co.uk/forum/v...=5510#post_5510
Edited by Richie on 25th Mar, 2008.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
