| Home > Help Needed / General Tech Chat > Faulty electrics!! | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
24th Mar, 2008 at 07:39:22pm
Im not shit hot on electric.
Shit Happen's |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Mar, 2008 at 07:48:12pm
Corrosion on the terminals of the fuse box, also the butt crimps that sit under the slam panel both have given me grief over the years.
24th Mar, 2008 at 07:51:15pm
On 24th Mar, 2008 shane said:
Corrosion on the terminals of the fuse box, also the butt crimps that sit under the slam panel both have given me grief over the years. Shane Whats the butt crimps that sit under the slam panel ? Shit Happen's |
24th Mar, 2008 at 07:56:52pm
Open your bonnet and take your grill off, under the bonnet pop there with be bullet connectors. I think they are for high and low beam, indicators and side lights. Give them a wiggle with your lights or indicators on, if the lights come on or flicker then there could be a bad connection. If there is take it appart and clean it. Also check the plug under the steering column inside the car. In situations like this it is worth while getting a £10 tester from the like of Halfrauds. On 7th Nov, 2008 Nic said:
24th Mar, 2008 at 07:58:14pm
There are a few black terminal crimps (bullet type) which supply the head lights situated under the slam panel these suffer corrosion, but as your having probs wit the indicators as well, I would check the fuse box.
24th Mar, 2008 at 09:04:51pm
do what he gents say above
24th Mar, 2008 at 09:08:50pm
Also have a look at the indicator/high beam switch on the column, if this has crapped out it could affect both headlight and indicators.
