Home > Help Needed / General Tech Chat > copper brake pipes
would anyone be able to knock me up a couple of copper brake pipes up M10x1mm male one end, M12x1mm male the other end, 55-60cm long?
I'm stuck as no one round here seems able to provide the M12 ends.
M12x1 sounds a real bastard size, what are you wanting to connect M12 unions to?
Pug 106 rear wheel cylinders.
Off to the scrappy you go for a pair of s/h unions to suit then! Then just get these made up into the pipes you need.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
isnt the lower one on the GMC227 mini master cylinder also M12?
Don't forget to call it kunifer or what-the-fuck-ever, otherwise some anal twat will decide to mention that copper isn't suitable for brake lines...
Many motor factors do sell copper brake lines, which are cheap crap.
Kunifer is a much better material to use, albeit slightly harder to bend and more expensive.
Copper is just plain crap.
Yes, isn't it? I've been looking all over the world for some banjo bolt that fits here...
