Home > Help Needed / General Tech Chat > head chambers
keithvplumb
Member #: 2352
staffs
is there a specific way to measuring the chamber volumes in the head and what do they need to be for a turbo.is there any way of reducing them if they are to high.thanks
steveobennet
Member #: 1657
wirral
this has been discussed numerous time, please take time to use the search function.
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
You need to accuratley measure the volume using a burette. Stock volume is usually around 21.4cc. On a Turbo motor you are generally trying to lower the compression to allow you to run more boost, so enlarging the chambers is what you'd want to do. On a NA motor you usually want to raise the compression, in which case you skim the head to reduce the chamber volume and raise the compression.
Richie
Member #: 628
I have 28 cc chambers with stock turbo pistons and i think my CR is 8.4:1. as per Phils reply but i used a syringe, anything that can acurately measure volume *wink*
if you want a head cut speak to BENROSS *wink*
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Sir Yun
Member #: 1592
Smart Guy!
nowadays i just set up the head dead level (using a level) and don't faff around with a plexi plate with holes in it.
i allways have trouble with air using that. and if you use a miniscule amount of vaseline to wet the chamber edges the results are accurate enough (well within 0.5 cc). i use alcohol btw
Edited by Sir Yun on 27th Mar, 2008.
