| Home > Help Needed / General Tech Chat > Starter Motor Current | |||||||
29th Mar, 2008 at 12:40:37pm
Does any one know how much current the starter draws?
29th Mar, 2008 at 12:49:16pm
Go for the 300 Amp stuff. On a cold day you're likely to excede this.
29th Mar, 2008 at 01:06:07pm
I'd go for the biggest that will fit in the channel, looking at the sizes thats probably the 300A stuff as Wil says. Edited by Tom Fenton on 29th Mar, 2008.
29th Mar, 2008 at 01:35:13pm
35mm welding cable is ideal, and plenty for a Mini.
29th Mar, 2008 at 04:21:43pm
I use 16mm2 on my car, and all the mini7's and miglia I wire up, never had a problem on any, but they all use the smaller starter motors On 15th May, 2009 TurboDave said:
29th Mar, 2008 at 04:58:14pm
i used 16mm on my old car after the std one rubbed through the grommit int eh boot and caught fire. Never had any problems with it, disconnected the ignition and cranked it over for 2mins constant and the wire didn't even get warm. On 20th Oct, 2015 Tom Fenton said:
29th Mar, 2008 at 06:06:11pm
A cable is rated for a constant current. A 100A cable will be fine for 300A for short bursts. However, unless you are really bothered about saving weight I would go for the 300A stuff. http://www.twin-turbo.co.uk
29th Mar, 2008 at 06:29:50pm
A pre-engaged BMW takes approx 180amps.
AlexF |
