| Home > Help Needed / General Tech Chat > rocker cover | |||||||
5 Posts Member #: 2196 Junior Member surrey |
29th Mar, 2008 at 06:03:42pm
does anyone know if you can buy rocker covers to fit over
29th Mar, 2008 at 06:09:29pm
The minispares ones fit over.
29th Mar, 2008 at 06:12:30pm
The MG metro rockers fit over 1.5s. The MS ones are a bit tight and need tapping back to clear the rockers. http://www.twin-turbo.co.uk
29th Mar, 2008 at 06:13:48pm
What with no chaffing ?
29th Mar, 2008 at 06:34:20pm
I had to grind the iside of my rocker box to clear the 1.5's. |
29th Mar, 2008 at 11:29:22pm
Basically, if you fit the MG cover and half tighten it. The tap it back towards the bulkhead with a hammer. The tighten it down. This is what we do with the TT and it is fine. http://www.twin-turbo.co.uk
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
30th Mar, 2008 at 12:59:50am
Agreed. Use a new rocker gasket, with an MG rocker cover - fits fine. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
30th Mar, 2008 at 12:01:26pm
On 29th Mar, 2008 jonnyh said:
What with no chaffing ? yes no chaffing........... wheres Nic
30th Mar, 2008 at 04:16:17pm
hahaha
31st Mar, 2008 at 11:24:09am
I had to modify (grind) an MG one to fit over MED rockers (and not the expensive LD ones). I think the make of rockers will affect which covers do and don't fit.
![]() 902 Posts Member #: 111 Post Whore Loughborough |
31st Mar, 2008 at 04:36:57pm
My alloy ones doesn't fit over my Minisport rockers. keep grinding more out of it to try and sort it. Could do with getting a steel orringal one again.
