Home > Help Needed / General Tech Chat > Another oil q
Ric
Member #: 36
Basingstoke
Finally got round to changing the oil in my mini. No idea how old the stuff that was in there was, but it will have been at least 6 years!!
I think the stuff that was in there before was a bit thin, when i got the car hot, it had very little pressure at idle.
So, I went on the hunt for some decent 20/50. Halfords had none, neither did my local motor factors so i put a load of wilkinson's cheapo 20/50 in.
Filled it up, getting decent pressure, let it run up to temp then gave it some stick. Now the turbo is louder than it was before, not the whistle but a high pitched wirring sort of noise.
The oil is obviously the cause so will be getting dropped straight away, my question is, what does everyone else use and where do you get it from? Is 20/50 too thick for the turbo?
Nick
Member #: 154
Midlands
i used to run the cheapo 20/50 when i had an oil leak and it was pretty rubbish, went like piss water when it was hot. normally use the halfords/duckhams 20/50 but millers also comes well recommended by a few chaps on here.
Ric
Member #: 36
Basingstoke
so 20/50 is ok, just not shitty 20/50?
i use 20/50
theres boobies on the tv and valvoline do something thats quite good and not too expensive
i cant remember what it was called though
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Valvoline VR1 20/50
On 19th Jan, 2010 wil_h said:
What has that to do with oil?
Edited by Rob H on 30th Mar, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
oil & boobies....answered your own question Rob!
colas
Member #: 102
Pennsylvania USA
I use Castrol 20/50. Had no problems with it yet.
nothing less than 15/40 grade
in the benross machine i run 20/50 changed ever 300 miles mind you it gets some bongo!
remember the engines many years old in desighn
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
I was gonna go for this stuff...
DONT!..... its reclaimed oil Duckhams 20/50
hammoj28turbo
Member #: 1502
Ahhhhhhhhh, thats why it cheap then.lol
I wont be using that. Cheers.
PLEASE! READ This and take your time ... it well bears out with most peeps Experience on here ..............*wink**wink*
http://www.mototuneusa.com/break_in_secrets.htm
Edited by BENROSS on 1st Apr, 2008.
