| Home > Help Needed / General Tech Chat > Clutch adjustment | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
31st Mar, 2008 at 02:24:39pm
OK - I'm sure this has 'sort' of been covered before but...
31st Mar, 2008 at 02:32:42pm
have you loosened the big nut in the middle?
31st Mar, 2008 at 02:44:32pm
Clutch was assembled as per Haynes so clucth should be on OK. Its new and uprated, lightned back plate (cut back lugs as turbo dave mod) grey diagrapham and racing plate. Which 'big nut' do you refer to Nic?
31st Mar, 2008 at 03:54:14pm
I've got gears now and can get the car to travel - it was adjustment on arm and throw out stop but... Lesson learnt when in nuetral there is a loud rattle from wok - whats the betting on clutch release bearing failure? The ONLY part I didnt replace!!
31st Mar, 2008 at 04:00:29pm
a friend had a loud rattle from the wok after sorting the clutch. turned out to be the flywheel fretting on the crank! |
31st Mar, 2008 at 04:04:33pm
Were there any other symptons? Like did he have the noises when in drive etc?
1st Apr, 2008 at 01:44:20pm
do you have straight cut drop gears?
1st Apr, 2008 at 01:50:38pm
On 31st Mar, 2008 Turbo Shed said:
a friend had a loud rattle from the wok after sorting the clutch. turned out to be the flywheel fretting on the crank! Ive had exactly the same thing I know its a ball ache, but Id take it apart and check this asap "Turbo's make torque, and torque makes fun"
3rd Apr, 2008 at 02:02:43am
On 1st Apr, 2008 Nic said:
do you have straight cut drop gears? these rattle like sin on idle, should go when you put your foot on the clutch i think that big nut is otherwise known as the throw out stop (i couoldnt remember the name of it) IF you have the adjustment john, so the large nut on the clutch housing is not impeding the full through of the the arm and you get all the gears as said by Nic and all works OK! then its the drops on idle buddy, they are very loude especially when the oils hot
depress the clutch and the noise goes .. right ? .......... thats it buddy YOU have a RACE MOTOR please make sure the ignition and fueling are correct john for THE BOOST YOU WANT...... then go kill some chavs be carefull PLEASE!
....LMAO ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Edited by BENROSS on 3rd Apr, 2008.
3rd Apr, 2008 at 08:05:27pm
muhahahahhaahahaha and never look back |
4th Apr, 2008 at 06:14:15pm
Yep - thats what is was!! I'm still running thre 'mutha' in!! Another 200 miles and an oil change then its time for some real boost. Pictures will follow soon!!
4th Apr, 2008 at 06:43:27pm
phew, glad to hear it was nothing amiss! "Turbo's make torque, and torque makes fun"
be carefull PLEASE!
