| Home > Help Needed / General Tech Chat > Brake servo | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
1st Apr, 2008 at 08:47:01pm
How should the pedal feel on a mini with a late type brake servo with the engine NOT running? just fitted one on my car but can't take it on a road test due to other bits. but the pedal doesn't build pressure up when pumping the pedal. its not lossing fuild from the master cylinder. could be large air bubble i guess but i just don't know how the pedal should be on a servo. |
1st Apr, 2008 at 08:48:33pm
you need to have the engine running to bleed the brakes when youve got a servo-have you done this? |
1st Apr, 2008 at 08:50:45pm
no i havn't. that will be fun to do... just used a power bleeder... ooops |
1st Apr, 2008 at 09:02:10pm
power bleeder should do it ok, that is what i used to do mine and all was fine. servo should feel nice and hard without the engine running as there is no vacuum to help assist. |
1st Apr, 2008 at 09:50:26pm
I'll have to try re-bleeding then, maybe just by pumping the pedal? Or am I best using power bleed, with or without engine running? Edited by Alex1340 on 1st Apr, 2008. |
1st Apr, 2008 at 10:13:34pm
On 1st Apr, 2008 Alex1340 said:
I'll have to try re-bleeding then, maybe just by pumping the pedal? Or am I best using power bleed, with or without engine running? I have never used a power bleed, and with the late type servo (that are attached to the master) I dont see why the engine needs to be running, but with the early remote type that may be true.. The worst bit is getting the air out of the master so that it will pump. I just fill the resovoir, put a pipe on one of the bleed nipples, open the nipple a bit and bugger off for a couple of hours. it drains down and I fill up again and close the nipple once the fluid is draining again. It seems to work, done this maybe 4 times now.... I use a 4 ft piece of clear pipe with a strong light to bleed so that I can sit in the car and easily see when the pipe goes clear of bubbles. Once you think its clear, keep pumping!! theres always a few more bubbles in the line. I use a fair amount of fluid, better safe than sorry!! and yes, the pedal should be fairly hard when you are done.. Edited by Turbo Tel on 1st Apr, 2008. website:- http://www.terryhunt.co.uk
