| Home > Help Needed / General Tech Chat > orange diaphragm | |||||||
112 Posts Member #: 1613 Advanced Member N. Ireland |
2nd Apr, 2008 at 01:20:55pm
Edited by bertieboo on 2nd Apr, 2008. |
2nd Apr, 2008 at 01:24:06pm
It's not a big deal to change one in situ (don't even need the flywheel off). So give it a go, if it slips change to a grey.
2nd Apr, 2008 at 01:27:26pm
It'll slip.
2nd Apr, 2008 at 01:44:11pm
oh. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Apr, 2008 at 01:48:54pm
Ok cheers for that! Would rather get it right now, as its easier to change now rather than in the car! |
2nd Apr, 2008 at 02:43:15pm
On 2nd Apr, 2008 wil_h said:
oh. ah, but that's only because my 8psi makes so much more power than any other mini ever invented ever. On 17th Nov, 2014 Tom Fenton said:
2nd Apr, 2008 at 02:49:06pm
My verto never slipped once with 15psi.
In the 13's at last!.. Just |
2nd Apr, 2008 at 03:00:28pm
On 2nd Apr, 2008 TurboDave said:
ah, but that's only because my 8psi makes so much more power than any other mini ever invented ever. That's fighting talk. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Apr, 2008 at 03:06:50pm
turbodave - ok, well if thats true my engine wont be anywhere near that.
2nd Apr, 2008 at 04:10:08pm
Orange will crap out at circa 100lb ft with the organic plate. No playing with lug heights will help that. Swap it out and forget the clutch as being a weak point. Edited by turbodave16v on 2nd Apr, 2008. On 17th Nov, 2014 Tom Fenton said:
2nd Apr, 2008 at 04:19:18pm
there we go, straight to the point. Cheers |
2nd Apr, 2008 at 04:46:05pm
crap out Love that phrase! We use it a lot at work here but never usually see/hear it out of work!
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
3rd Apr, 2008 at 12:37:09am
I'm using an orange diaghram with an AP paddle plate. 16 PSi boost on 1293 MED bottom end, big valve head etc... and it holds up fine. The whole clutch assembly was supplied by MED though so lugs where probably machined before hand.
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
3rd Apr, 2008 at 01:17:09am
coupe, is you boost gauge right ?
3rd Apr, 2008 at 02:35:35am
Boost gauge reads about 1 PSi high at 17 PSi, hence running 16 PSi - confirmed by an accurate calibrated oil filled type doobrie. Running on a standard rebuilt Metro Turbo T3.
3rd Apr, 2008 at 02:44:36am
Well, i am well suprised
3rd Apr, 2008 at 02:47:31am
I've no doubt that the clutch will let go at some point. I've been fairly forgiving with the way I drive the car so far. However I'm going to Shakespeare this weekend for the RWYB, so I'll report back as to whether or not I've destroyed the clutch!!! On 15th Jul, 2009 fastcarl said:
![]() 171 Posts Member #: 621 Advanced Member nsw austalia |
3rd Apr, 2008 at 08:18:31am
i ran a blue dot with 6psi which was 97hp and 92ft/lbs with no slip, uped to a orange dot when the boost was raised and that was holding up with 10psi and 139hp and 120ft/lb torque 1152cc turboed mini clubman, most powerful 1.1L a-series?
3rd Apr, 2008 at 08:19:18am
How the hell an orange diaphram is holding up to that kind of torque is amazing ! Lol.
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
3rd Apr, 2008 at 12:27:21pm
I have an orange diaphragm and initially tried a standard turbo clutch plate. It lasted about 10 miles... I put an AP rally plate in, still with the orange diaphragm and it's held out for a couple of years and about 2500 miles so far. Currently got 144lb ft at 14 psi according to Emerald's RR. It doesn't get too much abuse as it's a sunny day road car, maybe I've just got lucky and have a good one? |
