| Home > Help Needed / General Tech Chat > Will this work ok? | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
4th Apr, 2008 at 11:04:16am
Hi chaps just after your opinions and advice if possible.
Edited by AlexB on 4th Apr, 2008. |
4th Apr, 2008 at 12:57:07pm
8:1 CR is pretty low, I reckon it'll be good for a fair bit more than 10 PSI, to be fair you might want to raise the CR up a bit.
4th Apr, 2008 at 04:08:37pm
and lightened duplex vernier timing gear. After going through this with Stu and posting on a couple of other forums ive found out that the its pointless going past about 10psi on the eaton m45 charger as it just heats the intake charge up without producing any power gains. Stu also said that he can mod the bypass in my charger so as that it will run slightly more boost on the original pulley anyway.
4th Apr, 2008 at 04:09:40pm
actually just looking at that map i see its a 5th gen one , is the bini a 5th gen ?... goes and finds out ......
Edited by robert on 4th Apr, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Apr, 2008 at 04:52:11pm
Andy500 here is the link RobH was refering to .... http://www.mototuneusa.com/break_in_secrets.htm
4th Apr, 2008 at 04:57:38pm
there is a map in this link.
4th Apr, 2008 at 07:03:03pm
Hi guys, thanks for the replys so far and thanks to Benross for that running in data, thats excellent.
4th Apr, 2008 at 07:34:36pm
Robert, its not the efficiency of the compressor, its the inlet charge temps that are the problem. The VMax set up doesnt have much in the way of charge/ Intercooling. On 26th Oct, 2004 TurboDave16v said:
4th Apr, 2008 at 09:03:35pm
On 4th Apr, 2008 Andy500 said:
Hi guys, thanks for the replys so far and thanks to Benross for that running in data, thats excellent. Im very new to the forced induction game and didnt even know about things such as compressor efficiency until last week! How do i read those graphs. Im using the standard mpi pulley and a standard bini pulley on the charger, so dont know what that equates to in terms of revolutions and pressures etc. I just seem to be getting confused!!! Can anyone help and explain things more. sorry for being a dumb ass. Cheers not dumb at all andy , its inteligent to say if you dont know very generally ... the efficiency of the compressor whether its a turbo or a supercharger , is going to effect how hot the gas coming out of the charger is , the lower the eff ,the higher the temp , also the higher the boost ,the higher the temp . if the air is at a higher temp , it gets thinner so less power and also crreates more likelyhood of melting things on the engine . the map shows boost pressure in a form known as pressure ratio ,so the no 2 up the left hand side of the graph , equals 15 boost plus 15 atmospheric pressure all divided by atmos pressure 15 so you get 2 . if you lok at the boost level you want say 12 psi and add 15 the divide total by 15 you get 1.8 , then you find air flow for your engine , say that works out to 400m3/hr , you draw a line up the map to meet the 1.8 line ,and where they cross is your efficiency . this will then let you work out the air temp youll get out of the blowr , this is another calc , you can find all this stuff on garrett turbo site or some of the on forum calculators . with regards to the pulleys , ithink paul had a calculator linked if you do a search , but it will all come down to the comb of cam and head ,and ex etc ,how much boost youll get . regards robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Apr, 2008 at 09:06:49pm
Cheers for that robert, so how do i work out the airflow in to my engine? I aint got a clue! |
4th Apr, 2008 at 09:10:55pm
a nasty way is to say 150 cfm per 100 bhp . Edited by robert on 4th Apr, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
4th Apr, 2008 at 09:30:11pm
Using this
4th Apr, 2008 at 10:18:11pm
Hi chaps, and hi sprocket i think i met you last year at the finity rr day at minisport.
4th Apr, 2008 at 10:30:44pm
<3 that engine run in guide deffinatly how i am doing mine// did my dads car :) Drives
