Home > Help Needed / General Tech Chat > How big is an mpi crank pulley
Andy500
Member #: 2443
Cheshire
Hi chaps does anybody know what the diameter is of a standard mpi crank pulley? Mines at the machine shop so cant measure it too easily at the mo.
Also could anyone confirm that the standard pulley diameter of the eaton m45 blower on the bini is 65.5mm.
Andy
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
from memory mpi pulley is 120mm , if you're looking for psi's/rpm,mine only had 8 psi with std mpi/bini m45 pulleys,
