Home > Help Needed / General Tech Chat > Dismanteling the brake servo
minimatt
Member #: 2417
Hi i posted around a week ago about changing engine revs when using the brake, after replacing the non return valve the problem now is that the engine revs drop so i purchased a rebuild kit for a mk3 servo which i beleive is the worng one i was told when i purchashed the car the brake servo was from a cooper s which i beleive to be mk3?? http://minispares.com/Product.aspx?pid=34058 this seems to look the same as the one on my car but i have purchased http://minispares.com/Product.aspx?pid=34993. the problem i am having is that now when i use the brakes the revs drop so i beleive the diaphragm to be damaged is this correct? i have removewd the servo from the car but cannot for the life of me open it , is it even possible if so ther must be a technique lol
Turbo Tel
Member #: 588
Delaware, USA
I may have steered you wrong there, when you said a Cooper-S servo I assumed it was the Mk3 Cooper-S remote mount type.
http://www.minispares.com/Product.aspx?pid=38542
Where is the servo mounted?? Is mounted directly to the master? do you have a dual cct. brake system? If so Yes you bought the wrong kit. Thats the late (post 89) type.
If its the later servo mounted type you needed:-
http://www.minispares.com/Product.aspx?pid=34207
Not done this before so cant help on the disassembly..
Edited by Turbo Tel on 5th Apr, 2008.
minimatt
Member #: 2417
Hi tel thanks for the reply, yeh the servo is mounted to the master cylinder, its no biggy im sure i can return it no problem that looks like the right servo rebuild kit didnt see it before my self, the servo appears to twist apart but i cant for the life of me get it to seperte any one else done this before or is it comon practice to replace the servo when having problems?
minimatt
Member #: 2417
Can any one help me with this ??
minimatt
Member #: 2417
Sorry to bring back to life an old thread, but i could do with some help on this, im about to replace my servo but after reading a few post it seems that a few of you dont actually run them what do you replace them with and what is the process of doing it thanks
