Home > General Chat > minis blown up!
stevenford_uk
Member #: 144
made it back from avon safely, but today giving it some shit, i blew the headgasket!
nursed it home, should be done tonight, on the road again tomorrow.
Mini Stevo
Member #: 239
Somerset
now thats what I call swift work *wink*
Cheers, Stevo
Carl
Member #: 95
liverpool-on-sea
mine blew the head hgasket on the strip and i had to change it at avon to get home to liverpool *tongue*
b12
Member #: 247
Kent/Surrey Borders
sorry 2 hear your news mate
Still you will get it fixed *happy*
TurboLessTosser
MajicMini
Member #: 72
My engine popped aswell, although I knew it would being an N/A lump. It was nicely running 8 psi from the T25, but I couldn't fight the temptation to unwind the bleed valve, oops! *blush*
Arno
Member #: 233
Beugen, Netherlands
So my toolbox should contain a headgasket and a torque wrench as well as hand tools than?
Thats why you make the cars lighter, to carry a full workshop around, complete with fluids.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL no Arno... that why you tow with a Transit van!
alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
Or an RS2000!!!!!!!!!
Edited by giallofly on 19th Jul, 2004.
Carl
Member #: 95
liverpool-on-sea
if you dont run to much booost and have it set up properly youll probably be ok i failed both of these terrribly still theres a lesson somewhere
stevenford_uk
Member #: 144
yeah, i am running std boost at the mo, but it aint set up.
i think my actuator is weak also because its now seeming to over boost a lot! loads more turbo whistle and loads of turbo chatter.
so i am trying to take it steady till i can afford to have it set up.
If your actuator is weak it will not hold the waste gate shut properly and you will see less boost, if you're overboosting chances are your pipe to the actuator is leaking/split, this is probably the whistling sound .....
