| Home > Technical Chat > A+ and the Metro Turbo | |||||||
69 Posts Member #: 2461 Advanced Member Portsmouth |
6th Apr, 2008 at 10:05:01am
Hello all,
150 Posts Member #: 1591 Advanced Member Prudhoe, Newcastle |
6th Apr, 2008 at 10:09:21am
73.5mm bore with
6th Apr, 2008 at 11:37:48am
go for 73.5 and no further, makes 1380cc
6th Apr, 2008 at 12:38:01pm
Thanks for the posts.
6th Apr, 2008 at 03:38:54pm
On 6th Apr, 2008 T-shirt said:
'For high boost applications, because of the fact that it has less rigidity, avoid using the 1275 block which has a hole over the centre main bearing...if starting from scratch, use a turbo metro block'. Is he referring to an A series block rather than the A+, I have both a Metro A+ and a TurboA+ and have not seen a difference.. Terry Edited by Turbo Tel on 6th Apr, 2008. website:- http://www.terryhunt.co.uk
6th Apr, 2008 at 04:21:23pm
Not sure he doesnt specify - simply states '1275 block' on p.354 in bold writing if you have the book. |
6th Apr, 2008 at 04:30:29pm
The only block with the hole, is the A blocks up tp 71 or so it seems. On 13th Jul, 2012 Ben H said:
6th Apr, 2008 at 04:53:21pm
Well, I just looked and neither the A+ nor the Turbo blocks have a hole, I would say that he is reffering to the A series blocks.
6th Apr, 2008 at 05:12:29pm
Thats good news! thanks for the effort Turbo Tel.
6th Apr, 2008 at 05:17:09pm
you can use this.
6th Apr, 2008 at 05:50:00pm
Exactly what I need mini13 nice on:) |
6th Apr, 2008 at 05:54:57pm
AlexF2003 has a site, AFracing.co.uk which used to have a great Xcel file for all the CR/bore/stroke stuff but its gone.
