| Home > Help Needed / General Tech Chat > Selecting two gears at the same time | |||||||
6th Apr, 2008 at 06:45:47pm
I'm trying to remove the final drive of an old box and I can't seem to be able to select two gear at the same time.
6th Apr, 2008 at 06:49:42pm
You need to twist the interlock spool and selector shaft so that the selectors can move independantly. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Apr, 2008 at 06:58:19pm
Thanks Paul, I thought it was something like that, do I need to remove anything to allow me to rotate the interlock spool further than normal? Isambard Kingdom Brunel said:
6th Apr, 2008 at 06:59:35pm
6th Apr, 2008 at 07:00:20pm
yep, pull the dif side plate and the dentent spring, ball and strrl tube that suround them. On 28th Aug, 2011 Kean said:
6th Apr, 2008 at 07:00:38pm
If you have the diff out and the ball and spring out, it should twist OK. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
