Home > Help Needed / General Tech Chat > flywheel washer
mark4765
Member #: 249
is a flywheel washer definately needed on a pre verto clutch??? in my other post regarding obtaining a washer,one reply stated that they shouldnt be used as they soften and cause the bolt to come loose...as this is a major part of engine build,i dont want to mess it up.
regards mark
I used to use them, but now use loctite and locking wire.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Doesnt the loctite effect the torque down figure?
Alex
AlexF
mark4765
Member #: 249
Alex
shouldnt do really alex if its tightened before it starts setting
mark4765
Member #: 249
any pics or advice dave please
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Any lubrication on threads changes the torque figure...
Which is why most threads are quoted "clean and dry".
It doesn't really matter in most cases, but in this one we are bolting onto a taper, not sure over tightening is a good thing in this case!
Alex
AlexF
Ever measured the 'release' torque of a flywheel bolt that's been sat under a locktab? It's usually between 60 and 100 lb ft...
That thread can take a lot more than 150lb ft, so just get the thread de-greased, apply a small amount of loctite (not covering the thread) and get it wazzed up!
Lockwire is extra security - a belt and braces if you will...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I can't say I have!
The Air gun make short work of the bolt every time!
alex
AlexF
ha ha ha!!!
The pleasures of a flip front!!!
I will make a flippy fronty mini one day!!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Never bothered doing a clutch in the car..
then again its only 30 mins to get my enigne out!
I love flip fronts and no IC!
alex
AlexF
i did the clutch in the van, fook me thats tricky with having a fixed grill, infact anything is, even stupid things like getting dizzy's alternators and starters out takes 10 times as long!
hence the frog will be getting the chop! *wink*
I love my air gun too!
