| Home > Help Needed / General Tech Chat > more Draw through adavice needed. | |||||||
11 Posts Member #: 2450 Member |
7th Apr, 2008 at 03:27:48am
When running a draw through turbo setup, is it a necessity's to run carbon seals in the turbo, to insure u don't mix the gas with the oil? Dont suppose there are others with draw through turbo's that can give me some advice. |
7th Apr, 2008 at 01:53:46pm
In short, yes - it is required. Turbo life will otherwise be very short (like days / weeks, not months)... On 17th Nov, 2014 Tom Fenton said:
7th Apr, 2008 at 06:22:55pm
you can run a second butterfly btween the turbo and engine ,this protects the turbo from vacuum , it opens and closes with the carb butterfly , it worked on the mini suck through i worked on . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
7th Apr, 2008 at 08:33:32pm
ahh, so you'd ideally have the one between the engine and turbo slightly smaller than the one between the turbo and air filter, or is it not too critical. That's pretty cool - I never thought about that. :) On 17th Nov, 2014 Tom Fenton said:
7th Apr, 2008 at 09:01:33pm
it had to close slightly earlier dave , it got over the problem of no carbon seal . i think pete got a seal in the end , but i do remembwr him tlling me that he ran with no seal and no butterfly and it was ok , i didnt see this though so cant substantiate it , it was going through a rapid delelopment program ,and i had a fair few turbo design jobs on at the time ,so im a bit hazy , it was 1985 after all lol. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
7th Apr, 2008 at 11:21:21pm
ok so what T3 turbo has a carbon seal standard. I know 280, 300z did or many turbos pre 89 i think... can any1 roll off anymore.
8th Apr, 2008 at 06:49:05am
I'm in the same situation myself. I've got a suck through setup, but have no idea of there's a carbon seal. On 13th Jul, 2012 Ben H said:
8th Apr, 2008 at 08:16:41am
I looked into this a while ago (for different reasons) and apparantly you just have to fit the alternative seal plate (the aluminium backplate of the compressor that houses the seal) and a different thrust collar (shorter and without the groove for the piston ring seal), and obviously the carbon seal package to match. Apparantly everything else is the same HOWEVER, I'm going by what the supplier told me, I haven't tried it.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
8th Jan, 2009 at 01:32:31pm
Vergard how is the draw through setup coming on?
Edited by nutter driver on 8th Jan, 2009. And on the 7th day........... God created turbochargers! |
