| Home > Technical Chat > Increasing road traction | |||||||
69 Posts Member #: 2461 Advanced Member Portsmouth |
7th Apr, 2008 at 06:57:58pm
Anyone got any comments on how to maximise grip for road use (slicks out then!) for acceleration purposes rather than cornering e.g. R compound tyres - anyone used them?
7th Apr, 2008 at 07:37:17pm
perfectly balance camber castor and toe side to side. perfectly balalnce your front corner weights.
7th Apr, 2008 at 07:40:05pm
Jeez that sounds majorly complicated! Does all that make a noticable difference? How to you reduce weight transfer?
7th Apr, 2008 at 07:47:13pm
it helps MASSIVELY, cant stress it enough, having lots of power meens nothing if you can t put it down to the road in a controlled manor. sticky tyres will only make any inbalance in your suspension appear even worse.
7th Apr, 2008 at 07:54:48pm
Yeah it is for a mini. Im contemplating lots of power but I am unsure as to how much hp. Im not sure where to draw the line. i.e. 120hp is the same as 200hp due to road traction capabilities? If it is possible to plant most of a 200hp mini onto the road then I will go that route.
7th Apr, 2008 at 08:09:15pm
it should do, you have removed mroe weight from the front wheels than the rear turbo 16v k-series 11.9@118.9 :)
7th Apr, 2008 at 08:18:32pm
[quote=evolotion,7th Apr, 2008]it should do, you have removed mroe weight from the front wheels than the rear
7th Apr, 2008 at 08:20:28pm
toungue in cheek when you said your weight loss concerned you.
7th Apr, 2008 at 08:21:49pm
Il just eat a few hundred pizza's later on and that will compensate for it! |
