Home > Help Needed / General Tech Chat > 1430 Engine + Eu Type Approval?
norwegian_mini_man
Member #: 2486
hey
does anyone know if 1430cc engines have EU type approval? i would love to fit one in my mini, but cant get it road legal over here if i cant get the engine type approved
someone please say they have the answer...
Who will know that it's a 1430cc without stripping it down?
Just build it so externally it looks like a 1275. This may mean that 1430 is out of your reach as you won't be able to fuel it with standard looking parts. Maybe 1380 is possible though?
Vegard is the man to help here.
The CC isn't a problem, retaining the fuel ignition whilst making some power is. Find an older car! :)
(referring to your 96 SPI quote)
On 9th Apr, 2008 Vegard said:
fuel ignition
Fuel igntion? WTF you on about V?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
its not allowed to put carbs on a 96 model SPI over here due to emissions.
If you have to retain the SPi set up, all is not lost, but you are restricted to choice of cam and using an ECU and injector off a Rover Metro GTa/ GTi. The ECU is identical in apearance. the outward apearance of the engine will be the same, though a K&N induction kit will benefit in this extreme.
A 1430 SPi can be a very good, driveble engine that will still pass emissions tests, as long as the cat is retained
Expect at least 100bhp and 100lbft with an engine that will not need to rev over 6800rpm, lol it cant anyway.
norwegian_mini_man
Member #: 2486
ok...
although i might be able to make it look like a 1275, it wont sound or perform as one...
i already have a K&N induction kit fitted, but where would i get hold of a metro gti injector and ECU??
fuel ignition
Could you please start paying attention to things from now on Tom?
http://www.turbominis.co.uk/forums/index.p...4173&lastpost=1
norwegian_mini_man
Member #: 2486
thinking again, its not like there are all that many minis about, and every one i have heard sound different....
are you sure i wouldnt be able to use the standard injector and ECU? if the ECU needs tweaked i have access to all the equipment needed to do so...
Leonard
Member #: 806
Cirencester, Gloucestershire
vegard did you mean fuel injection?
It would be a pretty shit engine if the fuel didn't ignite!
fuel ignition
I'm paying attention just fine, its you talking bollocks, fuel ignition MY ARSE!!!!!!!!!!!!!
norwegian_mini_man
Member #: 2486
an SPi (note: i) has fuel injection...
Leonard
Member #: 806
yes but vegard said fuel ignition.
He even quoted his own mistake, making himself look twice as stupid
norwegian_mini_man
Member #: 2486
ah....
Standard Cooper ECU wont cope with 100bhp 87lbft torque, even then it comes in at the ECU hard cut where the engine just stops *laughing*
Youc could fit a programable ECU like Megasquirt or VEMS into a standard Rover ECU case. Royal Pain In THe Arse!! Been there done that *laughing*
The Rover Metro GTi ECU is a direct swap with the Mini Cooper one. The benefits are that the ignition map is designed around a pent roof combustion chamber therefore less total advance. This is needed when you run a compression ratio of around 11:1 on the Kent 274 camshaft. The compression ratio is one reason you get decent numbers on the dyno. I actualy run 11.2 ish, but only ever used high octane pump fuel. I ran a programable ECU for a year due to the problems with the Cooper ECU. The power figure droped to 95bhp but the torque climbed to 101lbft, passed an MOT with flying colours! I then blew up the wideband lambda circuit on that ecu, but wanted to use the car for a Mini Event. Fitted a Metro GTi ECU. It drove as though it was meant to be, idled as it should.
So, knowing that the engine produced 100bhp in one way or another and 101lbft and the cooper ECU did not control the idle fueling at all and the Metro GTI ECU did not show any signs of problems, Id say it was the way to go.
Much of the sound is down to the exhaust, but if you retain the cat and fit a twin box system, its not exactly loud but it still set off car alarms as you drive past, LMAO, its very bassy :)
remember, you are restricted to the camshaft you can use with the SPi/MPi engines
Oh and its been a year since this *laughing*
http://www.youtube.com/watch?v=D95auqEsZP0
Was hoping to get the 16v finished for this this weekend, but as things go, Jackman is standing in for me with his car. Be interesting to see the results of a fairly standard engine with the hottest injection cam available :)
Edited by Sprocket on 10th Apr, 2008.
Damn :)
Injection.. It still took a while before I got it straight! :)
HA HA HA
Vegard was WRONG!
I love it when this happens!
I'm so sorry I cannot please you more often you prick *wink*
miniminor63
Member #: 672
Oslo, Norway
*happy*
Subtle as always *laughing*
That is OK you Viking cunt, I can wait till the next time xxx
norwegian_mini_man
Member #: 2486
lolish....
still doesnt answer the question of WHERE to get a Rover GTi ECU....
miniminor63
Member #: 672
Oslo, Norway
ebay
