| Home > Technical Chat > adjusting the mixture on a na hif44 carb?? | |||||||
10th Apr, 2008 at 07:23:01pm
hi
My build thread..
10th Apr, 2008 at 07:57:07pm
yes, its the screw behind and a bit below the fuel-in pipe.
10th Apr, 2008 at 07:58:19pm
Ah, on the mater cylinder side nearish the back. It's a flat head screw that also take a philips, like the idle ajusting screw. It's tight to get at though. On 7th Nov, 2008 Nic said:
10th Apr, 2008 at 08:59:03pm
so theres not one that adjusts the whole mixture.
My build thread..
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
10th Apr, 2008 at 09:40:30pm
The needle profile dictates the fuelling. You set the mixture at idle to be correct, then it's the profile of the needle which controls how much fuel passes through the jet. |
10th Apr, 2008 at 09:57:42pm
be carful though i set my carb up accidentaly using the mixture adjust screw through the revs instead of a diffrent needel (first time i had done it) and my car runs crap atm. i may re-conect one of my breathers to the carb as it seems twin breathers dont work as well for me atm. Drives
11th Apr, 2008 at 03:00:04pm
On 10th Apr, 2008 josh_tacon said:
so theres not one that adjusts the whole mixture. cheers josh Well in theory, if you move the screw it will affect the mixture throughout the rev range. But it really should be used to set the idle mixture, then the rest is controlled by the needle profile. As a quick fix you cold give it a turn and see what happens Fastest 998 mini in the world? 13.05 1/4 mile 106mph
