| Home > Help Needed / General Tech Chat > wanted one ahu1897 | |||||||
18 Posts Member #: 304 Member |
20th Jul, 2004 at 01:44:25pm
i assembled my head when done i noticed one intake valve stem much lower in the cap any body have one to sell garry |
20th Jul, 2004 at 01:51:01pm
what is it you want to buy?
AlexF |
20th Jul, 2004 at 02:06:39pm
id be findin out why its lower in the cap first |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
20th Jul, 2004 at 03:18:36pm
if the valve caps are not level when assembled you will snap a valve , i know you will cos i did .
20th Jul, 2004 at 03:30:07pm
the exhaust cap has a groove cut in they all fit the intakes have a small ridge around the hole i have three the forth one is different it matches the single grove valve cap when together the top of the valvestem iis flush with the cap |
20th Jul, 2004 at 03:36:45pm
just a helpful hint here:
AlexF |
20th Jul, 2004 at 03:39:53pm
so what your saying is that the 4th cap is a different one and doesnt give the same assmebled height?
20th Jul, 2004 at 03:40:44pm
ok alex i need a valve sping cap for a three groove intake valve sorry to be beating around the bush garry |
20th Jul, 2004 at 03:44:02pm
Arr got ya!
AlexF |
20th Jul, 2004 at 03:44:11pm
Iain,Yes I am short 1 cap-I called Mini Mania,they have had none since '02.They claim they acessed MiniSpares stock-and they have none.Yes 4th cap is different-resembles a single groove cap.So-here I sit.......Garry |
20th Jul, 2004 at 04:20:32pm
alex check your email later garry |
