Home > For Sale > various A+gears..
i have lots of A+box parts if anybody needs anything,
also 3 sets of A+ transfer gears,(not mixed up)
plus 3 good casings.
i do not have a complete box built up but theres mora than enough to.
let me know what you need,
can post,
cheers Ron
What are the casing casting numbers?
More specifically do you have a DAM5626, the one that only used three tapped holes around the 3rd motion shaft bearing retainer.
Rod.
il check casings this afternoon
johnK
Member #: 690
Norfolk
pm'd
If Carling made Mini engines
ok i have 4 5626's
one complete with 3.1 but has broken 1st gear
the other has no diff or pinion but all the gears are ok
the 3rd is a pre a-plus and has a broken all the teeth from the 4th gear.
the 4th is a 5626 but i thinkits broken around the dif casing so would be scrap,but all the gears are intact
the 5th is a 5626 but ive not yet seen the condition as ivenot stripped it,the engine has damage on the block face so unless it was skimmed its no good??i was given the engine as ceased...
before you say,no im not a hoarder i was given all this when i bought the car!!
lol
cheers Ron
Edited by rubicon on 12th Apr, 2008.
If you have a 3.1 or 3.2 CWP that you'd part with I'd be interested.
Joe.
There is a guy over here who is always ready to pay money for complete (good) A+ gears/mainshaft and diff cages.
PM me your email addy
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Joe.
Actually, if you have two 3.1 or 3.2 CWPs I'll take the other one.
On 7th Nov, 2008 Nic said:
naeJ
m
johnK
Member #: 690
Norfolk
Ron - I'll take the box without gears and the box and block combo pls - pm me details
johnK
Member #: 690
Norfolk
doh - meant the box without diff!!
cheers
JK
