| Home > Help Needed / General Tech Chat > Laptop problem | |||||||
14th Apr, 2008 at 03:06:22pm
Hard drive failed on my laptop, I bought a new one and fitted it and it's now asking for a "system disc" when I turn it on. What's a system disc? Anyone got one I can borrow?
249 Posts Member #: 513 Senior Member Sheffield |
14th Apr, 2008 at 03:16:50pm
It's looking for a drive with an operating system on, which would probably be the faulty drive you removed. So you're gonna need to install an operating system to the new drive. If the laptop came with any cd's have a look for a Windows disc or could be labeled 'system restore'. |
14th Apr, 2008 at 03:22:57pm
If it's got a floppy drive, you can make a system disk from any PC. It just contains the basic drivers needed to run the Windows installation CD.
In the 13's at last!.. Just |
14th Apr, 2008 at 03:40:28pm
Shouldn't need to bother with a boot disk if you've got the windows cd. Just thinking though, theres a good chance you might not have one as I've known laptops to be supplied with the installation files on a separate partition on the hard drive in place of a physical cd.
487 Posts Member #: 1495 Senior Member |
15th Apr, 2008 at 08:57:52am
Andy is right, most b*stard laptop sellers are too tight to provide cds like they used to so they make a small partition on the hard drive containing the restore info. Fine if it is just corrupt, but if the drive goes your stuffed. They normally try and make you burn your own backup dvds when u first get the laptop/pc. |
82 Posts Member #: 42 Advanced Member Doncaster |
16th Apr, 2008 at 12:42:09pm
Andy is right.
16th Apr, 2008 at 01:25:13pm
What model Toshiba, and how old?
16th Apr, 2008 at 01:51:50pm
get a copy of XP, install then go here for the drivers
16th Apr, 2008 at 02:31:46pm
You have a PM 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
