Home > Help Needed / General Tech Chat > gearbox build
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
as other thread thinking of going for sccr gears but carnt do it myself (carnt be trusted) from mini spares can any one give me a price for building it for me
thanks again
In alphabetical order:
Benross
Hogster
Icklemini.
Send a PM / email to those three, also taking into account where you are located relative to them, and get a price for a transmission with gearkit fitted. Make sure you specify if you want the diff fitted/shimmed as well.
I suspect each one gets a better discount from the minispares than you do, so i'd just ask them to supply the unit.
Make sure you advise on if you want 'clubman' or ST' ratios to avoid confusion.
Each one of these guys will do a good job, probably more so than a 'cough' specialist. I doubt prices will vary significantly as no-one is likelly to be making millions on this, more so doing it for the community.
Edited by turbodave16v on 15th Apr, 2008.
