| Home > Help Needed / General Tech Chat > Heat probs | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
17th Apr, 2008 at 11:43:50pm
Couple more probs that i need to sort, then i can go have it tunned. Temostat i have is a 88 and i have drilled four holes in it 6'5mm. I no people have done this with the 82 so is this a reason getting to hot?
18th Apr, 2008 at 12:18:41am
88c stat is way OTT for a tuned engine
18th Apr, 2008 at 12:22:12am
sucking
18th Apr, 2008 at 12:45:49am
On 18th Apr, 2008 Nic said:
sucking there you go again Nic ......lol
still no bird buddy ????????
18th Apr, 2008 at 12:46:50am
nope!!
18th Apr, 2008 at 08:58:07am
I thought it would be getting to hot cos the waters circling to fast and not having a chance to cool wouldn't thatbe incrested with a low one? |
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
15th May, 2008 at 09:23:37am
I use a 72deg stat.
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
15th May, 2008 at 10:47:21am
I have just changed from a 88deg to a 74deg and the difference is massive. I struggled with overheating using the 88deg. I have a side mounted MS large 2 core rad and just running an electric fan (ditched the original fan). |
