| Home > Help Needed / General Tech Chat > Steering colum. | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
18th Apr, 2008 at 09:30:56am
I have a little wobble in my steering colum, i have tighten the bolts up and the plate that it bolts to is in place but it seens the bottom dash rail is flexing. Any ideas?
18th Apr, 2008 at 09:36:29am
Are you sure the felt bush in the bottom of the steering column hasnt perished?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Apr, 2008 at 09:51:13am
if the dash is flexing and you have a cage, install a door bar between the legs on the cage and mount the column to that. |
18th Apr, 2008 at 09:56:40am
Mines done in the above way and you could swing off it its that strong! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Apr, 2008 at 10:09:54am
no cage. You can see the bracket the column is attacted to moving with it. I mite try doing the bush see if that helps but im wondering if i need some thicker steel to make some extra surport.
18th Apr, 2008 at 10:18:22am
I think the bracket attaches to the Pedal box iirc. Check the bolts are done up nice and tight. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Apr, 2008 at 01:16:40pm
As mike said, The bracket attaches to the pedal box and dash rail with a pathetic "clamp" type arrangement.
18th Apr, 2008 at 01:31:10pm
That clamp is absolute bollocks I hate it, have had no end of trouble with mine, everytihngs really tricky to get to - not to mention the "shear bolts" on it in the first place. The bane of my existence i think haha |
