| Home > General Chat > Dump valves on Diesels? | |||||||
![]() 253 Posts Member #: 851 Senior Member Hereford |
18th Apr, 2008 at 02:20:17pm
Hey.
18th Apr, 2008 at 03:10:49pm
Definitely worth fitting an intercooler, it has the same effect on diesel and petrol. However, a dump valve works on the shutting of butterfly and seeing a vacuum. There is no butterfly on a diesel so it won't work or give any benefit, as far as I understand it. Edited by Ben H on 18th Apr, 2008. http://www.twin-turbo.co.uk
18th Apr, 2008 at 03:13:05pm
Intercooler is worth it however it won't go any faster unless you sort the fuelling at the same time.
18th Apr, 2008 at 03:17:31pm
just to let you know it has both... i had one of these as a loan car it has a recurculating dumpvalve and an intercooler :) New shape
Edited by Paul R on 18th Apr, 2008. Drives
18th Apr, 2008 at 03:18:39pm
A friend of mine who is a bit daft fitted a dump valve to his Nova TD. It wasnt pipe into the engine in anyway tho. Something to do with rigging it to the brake servo. Just to achieve the psssst. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Apr, 2008 at 03:31:36pm
I wasn't after one for the noise, I wanted to fit one for the benifit, but as it seems, it would be a waste of time.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
18th Apr, 2008 at 05:10:41pm
I think they have intercoolers as standard iirc. You will be able to get more power by winding up the boost and sorting the fuelling. Do a load of reading on it, tuning diesel turbos is totally different from tuning petrols.
18th Apr, 2008 at 05:30:19pm
On 18th Apr, 2008 Tom Fenton said:
Intercooler is worth it however it won't go any faster unless you sort the fuelling at the same time. Dump valve on a diesel is an absolute 100% waste of time and effort. agreed with tom ..... dump valve not needed as there is no throtle to shut off and stall the turbine i have the same motor are you sure it does not have an intercooler on ? just run it get the economy and reliability thats what they are for
18th Apr, 2008 at 05:46:27pm
they have an intercooler. infront on the rad on the n/s or left hand depending if your being all EU about things |
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
18th Apr, 2008 at 07:18:08pm
if its an izuzu engine you can get loads of power from them, such on mig web, something todo with twiddling a few simple things and changing the intercooler |
18th Apr, 2008 at 09:04:02pm
On 18th Apr, 2008 Snakeii said:
sorry didnt see it was an S reg i thought they had intercooler as it was only small ones hidden away? i think i won though... Drives
18th Apr, 2008 at 09:42:51pm
just to let you know it has both... i had one of these as a loan car it has a recurculating dumpvalve and an intercooler :) New shape sorry didnt see it was an S reg i thought they had intercooler as it was only small ones hidden away? Are you sure it was a dump valve and not EGR? AlexF |
18th Apr, 2008 at 10:07:04pm
recurculating dumpvalve, looked like the old ford mondeo plastic ones not an egr Drives
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
19th Apr, 2008 at 02:26:00am
i am a little confused now, if its a 2 litre then its not the isuzu one i dont think, i have turned an astra and a nova isuzu td of my own up and the gains are simply amazing (the difference, not the actual performance, lol) i have also done a 205td with verry good results but they were all mechanicle pumps and i think that on an S plate yours will be ECU... go buy an isuzu one:) hehe |
19th Apr, 2008 at 08:29:06am
20th Apr, 2008 at 10:52:04pm
Ok thanks for all the info fellas, I knew you'd lot know :)
