Home > Help Needed / General Tech Chat > Fitting a Actuator
b12
Member #: 247
Kent/Surrey Borders
I have another actuator 8PSI it has a long threaded rod coming out of it !!
DO you know I am not really sure how to fit it
there what looks like 2 10mm nuts to hold it in place
and a rod my actuaotr screws into
Do i need to undo the end of the rod ; all the way there under the carb ??????????????
Also how much backlash do I need to set; and how do I do it ?!
Cheers guys
PS where feeeeeeeeeebs he aint been on in a while has he ?
S
TurboLessTosser
Arno
Member #: 233
Beugen, Netherlands
Do you think we have to look at a crx forum to find him?
Did he sell his mini?, Was he at avon?
he was at avon in his mini, said hello to him and a short chat but was very busy.
actuator is self explanatory when you see the old one. just 2 nuts and the rod to take off.
refit with about 6mm preload, i.e make the rod length short enough so that you have to pull it about 6mm to get it on the wastegate arm.
to be honest there a pain to fit with the engine in but not impossible, try removing engine steadies to lean it forward to gain better access.
b12
Member #: 247
Kent/Surrey Borders
Iain matey does that mean I need to get under tat carb; or is it just the 10mm nuts and then screw the new one in ?
TurboLessTosser
pot_dan
Member #: 326
bradford, west yorks
hey, sorry cant help, lol feebs net is not working (i think he got it cut off to pay for the mini, not joking) and we made it to avon, i was there with him looking like a lost sheep*tongue*
Dan
seriously mate its a bit hard to explain, you'll see what i mean when you take a peak. you'll see the 2 nuts on the back of the "tin can" bit of the actuator to take off then just take off the rod. SHould be ok without going under the carb, its sort of to each side.
remove the carb - makes it much easier...
The nuts are 7/16" (11mm) Across flats...
pot_dan
Member #: 326
sorry to hijack thread, but dave me and feeble looked all over for you, you were itehr at the disco thing or on the track, lol
maybee next time:)
Dan
b12
Member #: 247
Kent/Surrey Borders
ah thats nice !!
my weekend got distressed and I couldnt make it there !
I will go to the next meet whatever it is
Would love to put names to faces !!
S
TurboLessTosser
does the actuator arm get longer or shorter with boost?
longer with boost
goodo, i get longer when i get excited too
