Home > Help Needed / General Tech Chat > Front Subframe Mounts
Ric
Member #: 36
Basingstoke
My standard rubber ones are completely perished, so i'm going to be fitting a poly bush kit tomorrow.
I have new tower bolt mount things, floor mounts and the teardrops at the front. Haynes has been useless for advice on changing these.
Does anyone have any advice or tips before i get stuck in?
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Make sure tower bolts are in before you stick your head under the engine.
Quite straight forward really.
Ric
Member #: 36
Basingstoke
Got drivers side completely done, but have only changed the tower bolt washers on the passengers side.
Got the floor mount off, had to re weld the bolt plate thing as it has come loose. Tried to fit the new poly mount and the alignment was so far out it was impossible. Messed about for ages, then it started to rain so just threw the old one back on.
Even so, still feels tons better than it did.
