| Home > Help Needed / General Tech Chat > Force 10x7 and AO32R | |||||||
82 Posts Member #: 1278 Advanced Member Bedfordshire |
21st Apr, 2008 at 08:34:25am
Just wondered if you guys could help? i have a set of force wheels from carl and they are stunning the only problem is i fitted one of my A032r to it and is looks really stretched over a 7inch wide rim i know some people use this width but wondered if they have had any problems on trackdays with them breaking the seal or rolling off? any help would be appreciated
21st Apr, 2008 at 08:50:39am
I wouldnt worry. A few people on here are running that setup and havent complained. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Apr, 2008 at 08:55:42am
Are you using innertubes?
In the 13's at last!.. Just |
21st Apr, 2008 at 10:23:05am
no im not using inner tubes as a few people said bad things about running them and also there a tubeless tyre |
21st Apr, 2008 at 10:27:45am
I run innertube on mine. So does Fastcarl irrc. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Apr, 2008 at 12:25:11pm
I run them, with tubes, no problems On 15th May, 2009 TurboDave said:
21st Apr, 2008 at 12:36:12pm
i run without tubes but 6 3/4 x 10 with no problems Crystal Sound Audio said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
21st Apr, 2008 at 12:43:12pm
so whats the pros and cons of inner tubes then?? On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
21st Apr, 2008 at 03:38:14pm
i run them without tubes 10 x 7 |
21st Apr, 2008 at 07:35:08pm
the only reason im against them is that i spoke to stuart wright witht the blue turbo mini and he said they lasted about 250 miles and the other worry is that its a vauxhall powered mini im building with throttle bodies and other toys so i was just concerned about the extra weight |
21st Apr, 2008 at 07:36:23pm
wouldnt a vaux engine be lighter? its an ally block and head isnt it? Drives
21st Apr, 2008 at 07:38:15pm
if it is lighter it dont seem like it trying to lift it i was just worried about the weight and the torque last thing i want to do is risk injuring myself |
21st Apr, 2008 at 07:44:46pm
to be fair, all stu's car does is track days and drag racing. its not suprising they dont last long!
21st Apr, 2008 at 07:47:12pm
Did he mean the tyres or the tubes last 250 miles? On 5th Sep, 2011 Vegard said:
21st Apr, 2008 at 07:47:44pm
mine is gonna be track days mainly one of the guys who races sevens is building it and my main use is gonna be track days and some chav bashing |
21st Apr, 2008 at 07:47:46pm
pretty similar, but my Yoko 12" A048's have covered 2000 miles of not very sympathetic road use and the fronts are only just starting to wear really. Edited by minimole23 on 21st Apr, 2008. On 7th Oct, 2010 5haneJ said:
21st Apr, 2008 at 07:54:56pm
he meant the tubes only lasted 250miles so he doesnt run tubes anymore he said it just started rubbing after 250 |
21st Apr, 2008 at 08:02:30pm
21st Apr, 2008 at 09:47:17pm
there is no hard and fast rule on using tubes, mymain reason for using them was that i found it difficult to find as fitter who would tough my wheels, being spangly shiney, so i would fit tubes myself which allowed me to build the wheel up myself with tube in place,
22nd Apr, 2008 at 10:10:24am
I dont use tubes (7/1/4), Stuart fitted them for me :) he used his as a daily driver to work and back for ages (70 mile round trip) with no probs. |
301 Posts Member #: 2480 Senior Member Swindon |
22nd Apr, 2008 at 12:11:44pm
Where can you get 7x10s on the net? feature=mhum |
22nd Apr, 2008 at 12:16:56pm
PM "fastcarl" he is Mr Force Racing, makes his own 3 piece split rim 10" wheels for sale.
22nd Apr, 2008 at 01:07:37pm
On 22nd Apr, 2008 johnnysti said:
Where can you get 7x10s on the net? http://www.foxwebsitedesign.co.uk/6.html Isambard Kingdom Brunel said:
22nd Apr, 2008 at 07:17:00pm
i seem to be lucky then the fitting of the tyres to the wheels was no problem and there was no damage its just when you look at it there is a scary amount of stretch on the sidewalls to get them to the edge of the wheel and there is no gain as the tread width isnt any wider im just worried as on trackdays its going to get a fair bit of abuse and i just dont fancy risking it, and the guy who races sevens and is building the car was a bit dubious and reckoned i should go for a 10x6 |
