Home > Help Needed / General Tech Chat > MBC
b12
Member #: 247
Kent/Surrey Borders
does anyone else experiance a split second of overboost using the MBC ; mine will overboost by about 2PSI b4 settling down
Its a tad worrying !!!
S
TurboLessTosser
Soton1310Turbo
Member #: 265
Southampton
I bought one off of EBay and it's Chod!
Over boosts as yours does, and doesn't seem to boost high enough some of the time.
It's just not consistant
gone back to a bleed valve for the mo
Will try a better MBC sometime
What type of MBC is yours?
ball and spring?
The one I got was some sort of nylon valve inside
Keith
minster
Member #: 198
I use a brass check valve (grainger valve) it has a steel ball and spring and works perfectly with 10psi boost. No over boosting and it holds boost well. Even the rolling road operator commented on it.
Phil
I use a mega expensive ?5 std bleed valve, never had any problems so have no plans to change, maybe an amal valve in the future, but don't seen the advantage of an mbc
