Home > Help Needed / General Tech Chat > Rolling road
podule
Member #: 2286
rugby
Just fitted mjlj and intercooler and need to get it set up. Anybody no of a good RR close to rugby??? I know there is one in southam but they are not up to date with mjlj. Also would it be safe to drive it there on a base map ?
Guennie
Member #: 2328
Nr Newmarket, Suffolk
do most rolling road have the facilities to set up a mini with mjlj? i guess it's worth calling and checking first! sorry to hijack the thread but i was also keen to find out if it's safe to drive to an rr with the base map.
100% BMW Free
if your search about the megajolt and rolling roads you will find both of your answers most likly :)
Get familiar with the software yourself, and you shouldn't have a problem getting it set up most places.
Its only ignition advance at the end of the day so most operators should know what it should be at different points. If you know how to find your way around the MJ software you should be fine! *wink*
