| Home > Help Needed / General Tech Chat > Fuel regulator | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
27th Apr, 2008 at 01:03:00pm
Hi. My fuel regulator started leaking yesterday at a mates house so i had to leave the car there. Would it be ok to just remove the reg? Or are they essential? Do you all use them?
27th Apr, 2008 at 01:31:35pm
You can remove it if you wish, it wont rise with boost, however you wont need to worry about that as your carb will be seeing 35psi (or more) which will probably pop your carb seals
