| Home > Help Needed / General Tech Chat > Conrod Bushes | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
2nd May, 2008 at 11:29:01am
I have just brought some fully floating Omegas and am now looking at getting some bushes made and fitted into the small end of the rods. Can anyone who has done this give me a rough idea of how much i should be looking at paying for this to be done. This is one of the last things to get done before i start to put it all together.
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
2nd May, 2008 at 12:09:27pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9898
2nd May, 2008 at 01:03:17pm
You are right 'Searching is fun', that is why i done it first!!
2nd May, 2008 at 01:06:34pm
If the gudgeon pin doesn't fit, then it is not fully floating.
2nd May, 2008 at 01:54:29pm
On 2nd May, 2008 LukeAnsley said:
I am trying to find out about the gudgeon pin going through the rod, at the moment it doesn't fit!! When you say it doesn't fit, do you mean you simply can't push it through ??? In which case, that is correct, they are an interference fit (and quite a tight interference at that) so a hydraulic press (with suitable jigs) is required or very careful application of heat to the rod end. The other thread does mention making them floating, but by honing out the small end rather than by bushing it. Schrödinger's cat - so which one am I ??? |
2nd May, 2008 at 01:56:12pm
I am led to believe that with the 18cc forged omegas with the fully floating bush, you need to bore the small end out. And then fit the bronze bush. That is why the pins do not fit through the rods at the moment.
2nd May, 2008 at 02:10:37pm
sounds like rubbish to me,
2nd May, 2008 at 02:13:33pm
Can anyone tell me what the difference between the fully floating with circlips or fixed press type pistons are then?
Edited by LukeAnsley on 2nd May, 2008. |
2nd May, 2008 at 02:38:12pm
Sorry, I didn't realise Omega made a version specifically for a bushed rod end, I've only ever used interference fit pins (other makes of piston).
2nd May, 2008 at 02:41:52pm
On 2nd May, 2008 retired said:
If your gudgeon pin doesn't go in the rod end currently, then maybe you have the inerference ones anyway. So did you get supplied the bronze bushes with the type you chose ??? Anyway, around here, any decent machine shop would charge by the hour and I wouldn't want them to rush a job like that. Yeah the pins don't fit the rods at the moment, they are over 20mm. They didn't come with any bronze bushes, but did come with the circlips, so i presume that they are the floating type. I think that i will take a trip down to a local engineering place and see what they say then. |
2nd May, 2008 at 02:51:16pm
Maybe you've been mis-supplied ?
2nd May, 2008 at 03:21:27pm
depending on how many miles you intend to do, you can get away with just honing or reaming put the little end, the pin runs straight on the rod material, . when rebuilt this winter there was not a mark on the pins, thats what the oil is there for.
2nd May, 2008 at 03:37:48pm
I had read that some people were running the pin straight on the rod, and by the sounds of it with good results. The car might be doing quite a bit of mileage so that is why i liked the idea of running a bush.
2nd May, 2008 at 07:36:23pm
The omegas come with circlips so that you can run a floating pin if youu ream or bush the little end like you have said. Or you can use them without as a interferance fit.
2nd May, 2008 at 08:06:24pm
Steve @ MED will be able to assist as the Omegas I have required this operation (73.5mm flat tops thou) On 5th Sep, 2011 Vegard said:
7th Jun, 2008 at 05:27:16pm
Just thought i would let you know i have got the rods back from the engineering company today. They bored the rod out, made the bush, fitted the bush and honed it. And also drilled an oil hole in the end of the rod.
7th Jun, 2008 at 05:43:08pm
looks like a tidy job, |
