| Home > Help Needed / General Tech Chat > Supercharger inlet | |||||||
39 Posts Member #: 2402 Member |
4th May, 2008 at 01:10:51am
Hello.... My project is an supercharger blow-through setup...
Edited by Giancooper on 4th May, 2008. |
22 Posts Member #: 1909 Member Cracow, PL |
4th May, 2008 at 10:16:07am
Hi, I'm going similiar way - blow-throught, front-mounted charger in a roundnose mini. Have You considered turning the charger 90 deg so that the outlet of the charger faces down?
4th May, 2008 at 10:29:57am
Its to difficult to close the bonnet is you turn on 90° the charge... |
4th May, 2008 at 11:09:30am
44mm should be fine,
