| Home > Help Needed / General Tech Chat > R/H engine mount. | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
5th May, 2008 at 02:12:44pm
Hi there
I drill holes in everything..! |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
5th May, 2008 at 02:35:47pm
The 1 I use mounts on to all 3 theromstat studs and runs back and down towards where the master cylinders would go 4 a LH drive and mounts via a normal mini engine mount bolted 2 the firewall. Not pretty but works well. Hope that makes sense. "So wat we gonna do tonight Brain?"
5th May, 2008 at 02:40:19pm
mine mimmicks the same as the drivers side one and goes onto one of the water pump bolts, then a bracket the same as the drivers side attaches it to the bulkhead.
5th May, 2008 at 09:41:52pm
I must agree with Iain. The one that mounts to the waterpump is much better than the thermostat type.
In the 13's at last!.. Just |
5th May, 2008 at 09:48:34pm
i am using a thermostat style one on my N/a mini and it has reduced engine movment quite abit, got to say it was a pig to fit and even worse to remove, i like the idea of having it mounting somwhere else for when i come to turboing Drives
567 Posts Member #: 102 Post Whore Pennsylvania USA |
5th May, 2008 at 10:07:19pm
I use the thermostat one and it uses 1 bolt of the exhaust manifold aswell. |
6th May, 2008 at 09:39:03pm
On 5th May, 2008 pinkyandnobrain said:
The 1 I use mounts on to all 3 theromstat studs and runs back and down towards where the master cylinders would go 4 a LH drive and mounts via a normal mini engine mount bolted 2 the firewall. Not pretty but works well. Hope that makes sense. The sh*g nasty "ultimate" engine steady by chance? On 5th Sep, 2011 Vegard said:
