| Home > Help Needed / General Tech Chat > fastcarls crank thrust oil gallery upgrade or other | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
5th May, 2008 at 07:06:07pm
cant find any info on this and yes i have searched, basically after 2000 miles with little abuse my thrusts have given up, grey plate and all set up properly, will pop picks up when i find out as i know every one loves to see pictures, was a thread not long ago about chamfering the main bearing but cant find that "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
5th May, 2008 at 07:12:28pm
here you go,
5th May, 2008 at 07:17:52pm
yes i did find them after a bit more searching in not the obvious place, why not just drill at a slight angle as the oil gallery goes straight down
Edited by nogin on 5th May, 2008. "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
5th May, 2008 at 07:20:54pm
5th May, 2008 at 07:32:33pm
also this is only on the side which the crank gets pushed up against, would be piontless doing both sides i guess, wouldnt one of those small electric screw drivers work as there small enough Edited by nogin on 5th May, 2008. "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
5th May, 2008 at 07:33:39pm
yep that what I thought, so you would only need to mod one of the four thrusts. On 28th Aug, 2011 Kean said:
5th May, 2008 at 08:33:52pm
would you do the bottom one on the clutch side as well? Just to stop the oil getting behind the thrust?
Edited by Jason G on 5th May, 2008. On 19th Jan, 2010 wil_h said:
5th May, 2008 at 10:32:28pm
yes you need to fix both thrustsm back, use a small elec drill and dont break the bit in the block,lol,
5th May, 2008 at 11:06:28pm
I actually came out with a sensible answer! Cheers fastcarl...another beer I owe ya! On 19th Jan, 2010 wil_h said:
282 Posts Member #: 1404 Senior Member The Netherlands |
4th Dec, 2010 at 09:20:47pm
there is nothing wrong with a A-series that a turbo can't fix.
4th Dec, 2010 at 09:36:44pm
On 4th Dec, 2010 paneermeel said:
Hi, i took the engine apart and i want to do a lot of mods to build a better engine. One of those mods is to get more oil to the trusts. I found the solution Carl made. But to keep it simple: What if you make a groove in the main bearing to the trusts? This way more oil gets to the thrusts then normal. Carls solution gets the oil more direct to the trusts but one thing that i keep thinking: What if you drill youre block and thrusts and you need to replace the thrusts? How do you get the new thrusts alined with the already drilled holes? Modding the bearing can be repeated again and again and ag........ Has anyone tried modding the bearing or has more info about it. Regards Paneermeel Putting a groove in the bearing as you suggest will ruin the lubicating film on the main bearing. There is more than enough oil leaving the main bearing to oil the thrusts. It drains past the thrusts at very low pressure, almost zero probibly, and the oil is drawn into the thrust bearing. The real problem is that with excessive pressure from an uprated clutch with such a small thrust bearing surface area, the oil film is overcome. Feeding oil onto the thrust face at pressure helps maintain the oil film. On 26th Oct, 2004 TurboDave16v said:
4th Dec, 2010 at 11:22:32pm
One of the big problems is getting the crank hardened then polishing the thrust faces - not grinding them. If theyre just polished the carbon that creates the case hardening creates a rough sandpaper like surface that wears the soft bronze material away very quickly.
I seriously doubt it! |
5th Dec, 2010 at 09:46:15am
I changed the van's std thursts for bigger ones after Carl had modded them for us. I used the original thrust as a template to drill the new one. As long as you are careful it will be fine. On 11th Feb, 2015 robert said:
5th Dec, 2010 at 10:03:01am
On 4th Dec, 2010 paul wiginton said:
One of the big problems is getting the crank hardened then polishing the thrust faces - not grinding them. If theyre just polished the carbon that creates the case hardening creates a rough sandpaper like surface that wears the soft bronze material away very quickly. It needs to be ground to get a nice finish This makes sense. I wonder how many of the thrust failures seen have some way in part been caused by this. If something is worth doing, it's worth doing half of. |
5th Dec, 2010 at 10:14:25am
you do not need a 90 deg drill, i set the tapping drill into a piece of 6mm bar 200mm long, this way you can almost get the threads square to the face, iv'e nevrr had any problem doing it this way .
8th Jan, 2011 at 08:02:23pm
I got a call from the workshop who is doing the work for me.
8th Jan, 2011 at 08:08:59pm
Yes you need them otherwise the oil is pressure fed behind the thrust awell making the thrust push against the crank at all times I seriously doubt it! |
8th Jan, 2011 at 08:09:59pm
they are needed as you need to make sure the oil goes the right side of the bearing On 28th Aug, 2011 Kean said:
9th Jan, 2011 at 05:41:21pm
ok then, tomorrow i will get some brass screws to get the last part done.
