Home > Help Needed / General Tech Chat > Brake bias valve
Turbo Rich
Member #: 551
Ashington W.Sussex
Hi all
Because I am still having odd behaviour with my rear brakes I have decided to ditch the original pressure reducing valve on the bulkhead and fit a brake bias valve instead. I have seen the following valve:
http://www.compbrake.co.uk/TECHNICAL_BIAS.HTM
Can anyone tell me if this is suitable and also if it will fit the threads on my existing pipes. I am hoping to do a direct swap and mount it somewhere on the bulkhead.
Rich
I have a lever type valve in my motor, the fittings should be 3/8 (mine were anyways) just make sure theyre 3/8 fitting and it should be suitable. Make sure you set it up on a set of rollers at an MOT centre.
Alex1340
Member #: 111
Loughborough
I have the lever type as well, easyer to adjust while driving.
