Home > Help Needed / General Tech Chat > Help for the carb....
Giancooper
Member #: 2402
Hi guys, I need to turbing my n/a hiff44, I try whit serch button but I didn't found..:$.. I need an HELP please....
What I have to do?
I need just to put the o-ring on the dashpot like this photo?
(Click the Photo)
I need other thinks?
Ineed an help because I starting to came crazy!!!*surprised*
Turbo Tel
Member #: 588
Delaware, USA
Make sure the dashpot piston (the black screw in thing) does not have a vent hole.
I think the seals on the throttle shaft should be turned around.
The only other thing is feeding the pre-restrictor boost pressure to the fuel resovoir, not sure how that goes on a non turbo carb..
Giancooper
Member #: 2402
I reed on other topic tha the different is only on the o-ring..... Is it wrong? Any pics?
Edited by Giancooper on 9th May, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
The dashpot 'O' ring is the same as the one on the float chamber cover.
Yep, turn the seals on the throttle & choke spindles the other way round.
http://www.burlen.co.uk/default.aspx
Edited by Jason G on 9th May, 2008.
On 19th Jan, 2010 wil_h said:
I can supply you with a Turbo carb rebuild kit should you need one.
