| Home > Help Needed / General Tech Chat > internal clearance for bulkhead boxes? | |||||||
17th May, 2008 at 12:10:02am
hi, im putting a turbo and single weber box (probably minits if they have one) in my mini. the shell is a 1995. it has a single speed heater and full length rover dash.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
17th May, 2008 at 12:23:07am
Heater they do as you cut into the mountings. Top and Bottom dash rail though arent affected Back once again like a renegade master |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
17th May, 2008 at 10:17:52am
what i would perhaps advise is you weld an angled plate in the turbo box (engine bay side) so water does not gather there Edited by Richie on 17th May, 2008.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
17th May, 2008 at 10:52:26am
You won't be able to fit a cd player in the centre of the dash with a weber box as the box is too deep. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th May, 2008 at 11:51:15am
You could cut the bottom of the box & slope in down, its another water trap. Get some metal fill the gaps in the side afterwards. On 19th Jan, 2010 wil_h said:
i also made the back section (ie the bit that sits next to the heater) double skinned with a bit bar a bit like double glaze so to speak, it helps prevent the bulkhead getting so hot. inside the car.
