| Home > Help Needed / General Tech Chat > carb losing vacume | |||||||
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
17th May, 2008 at 06:52:12am
hello
17th May, 2008 at 09:12:58am
Don't really understand what is being said.
17th May, 2008 at 12:44:29pm
Checked the obvious pipework? Blocked, splits etc. Also check fuel pressure at idle. Around 4psi I think.
On 19th Jan, 2010 wil_h said:
17th May, 2008 at 01:13:30pm
hello
17th May, 2008 at 01:17:32pm
sorry its me again
17th May, 2008 at 06:27:31pm
Fuel regulator should come off the plenum. I'm sure the hose below the fuel supply to the carb is blocked off. The actuator pipe is the only part I'm unsure about. My setup is not the norm, so hopefully someone will help you there.
17th May, 2008 at 07:22:21pm
for the spiking megajolt, check the grounding of the edis unit and the megajolt, i THINK THEY NEED TO GROUND TO THE SAM POINT (ooops caps)
17th May, 2008 at 09:47:14pm
Have you been drinking again Joe?
In the 13's at last!.. Just |
17th May, 2008 at 09:50:17pm
I think hes been on one of those Green King tours at bury st edmunds!
17th May, 2008 at 09:58:26pm
lol Jason.
Edited by theoneeyedlizard on 17th May, 2008. In the 13's at last!.. Just |
17th May, 2008 at 10:02:28pm
On alandavies215 pipe issues, where do most of you connect the actuator pipe? If its sharing the pipe to the regulator, won't some pressure be lost?
17th May, 2008 at 11:11:55pm
lol,
18th May, 2008 at 07:58:58am
actuator pipe comes of compressor housing then t piece to your bleed off.
18th May, 2008 at 08:19:30am
than u hogster so if he conected to two together like he did will this cause it to go lean on boost |
18th May, 2008 at 08:44:30am
Still not sure how it's been connected. any photos? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th May, 2008 at 09:21:10am
sorry no
18th May, 2008 at 05:20:40pm
Yes, blank them both off. But the extension gasket outlet could also be used for the boost gauge, or dump valve, or MAP sensor. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th May, 2008 at 06:14:38pm
thanks wil have it sorted now going to order fuel pressure gauge tomorow and hopefully sort that as well
