| Home > Help Needed / General Tech Chat > Cutting out | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
18th May, 2008 at 04:39:44pm
Hi all. Recently had my car set up on the rollers (1293 turbo) but ever since when coasting in gear, going down hills, coming up to junctions etc the engine cuts out, its then really difficult to start, turns over for ages before eventually starting. Any ideas what could be causing this? Thanks in advance, Matt |
18th May, 2008 at 06:27:53pm
it could be a number of things matty
18th May, 2008 at 09:03:39pm
I had this on my na mini, was worse when the headlights where on, although its not a proper fix, but i just increased the idle slightly, worked for me 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
