Home > Help Needed / General Tech Chat > Achieving 3.2 FD
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Hi guys did a search, but got a bit confused as to how ago about achieving this final drive with my setup!
Ive got a s/c clubman gearset from minispares, a set of 1:1 trannex s/c drops and 13" wheels.
Will simply fitting a 3.2 crownwheel get me a 3.2 FD? I understand that standard FD is 3.44 is this correct?
From what ive read a 3.2 is a tidy FD for track/road use? What are your opinions? Lower?
Also, i bought the gearkit a while ago now http://www.minispares.com/Product.aspx?pid=36035
Ive only just realised it says for "A+ engines", have I made a mistake by getting these because ive got a metro turbo engine and have a feeling they're not "A plus" engines.
I hope to god ive not got the wrong kit as I cant find the receipt!! *surprised*
Edited by richminiturbo. on 18th May, 2008.
Metro turbo is A plus, gears should be fine.
The crownwheel and pinion must be fitted as a matched pair to get the final drive ratio. Which FD you have depends on what you want to use the car for. Most people run between 3.444 and 2.9
richminiturbo.
Member #: 719
Nice one tom cheers!
Car is going to be primarily regular road/motorway, and as many circuits as I can make it to, aswell as Avon etc.
So im looking for a general all round usable car really, but would prefer ripping away from a stand still but nothing silly which will see me bouncing valves at the end of the strip!
Will fitting a certain crownwheel+pinion to my setup mean the resultant FD being the ratio of the crownwheel+pinion itself? As I have 1:1 drops? Am I correct in saying that there isnt a huge difference in FD effected by the wheel size?
Ive been calculating road speed with 3.2:1 FD and my wheel size, in 4th, 4000rpm giving me a nice 73mph. From the figures i've been playing around with, a ratio higher than this doesnt really sound ideal for the road and track.
Ive tried 3.2, 3.1 and 2.95:1 and cant really see what would be best.
your pretty much right on everything,
the rolling diameter of 10s and 13's isnt normally hugely different, the 13's will be a tad "taller" by about 10% IIRC
I would say for all round use either 3.1 or 3.2 shouhld be pretty good. If you don't do any track and quite a bit of motorway then a 2.9 might be more suitable. also you'll get away with a 2.9 better if you have a helical box as 1st is lower.
one thing that might be helpful is.... the no of teeth on the big gear divided by the no on the small gear will give the ratio.
richminiturbo.
Member #: 719
Great thanks for the info!!
Aha by this do you mean the big gear being the crownheel and the small gear being the pinion?
Can I change the size of the pinion gear to get the ratio i want and keep the stock crownwheel then? Sorry if its a dumb question but ive not dealt with Final Drives yet!!
If thats the case, the standard crownwheel+pinion on a 3.44 is 62+18?
So if I was to get a 19 tooth pinion 62/19 = 3.26:1
Trouble is I cant see a 19 tooth pinion on minispares do they exist? Or am I going to have to look about for a smaller crownwheel to reach the magic 3.2 or 3.1?
Thanks again for the info
AHEM!
richminiturbo.
Member #: 719
On 19th May, 2008 Tom Fenton said:
AHEM!
Oh riiight *oh well*
So it sounds like im just going to have to fork out for a 3.2 crownwheel+pinion then?
Ive got a spare mg metro engine, im guessing thats got a 3.44:1 aswell?
Edited by richminiturbo. on 19th May, 2008.
AHEM!
"Should", not "must"!
Also, for track use 3,2 would be way too tall, but it's all a comprimise when road use also is considered.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I agree, now I haven't got my calculations back to front! cheers Joe. *wink*
Metros run 3.9 for racing...be quite crap for road use.
On 19th Jan, 2010 wil_h said:
richminiturbo.
Member #: 719
Hmmm ok.
Will the car be nice on the 3.44:1 if i leave it alone? Im not too bothered about it being abit silly on the road as i wont use it that regularly.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
According to the haynes destruction manual...3.44 is standard 1275 diff
richminiturbo.
Member #: 719
Yeah, im wondering if i should stick with the 3.44 ratio that it has as standard at the moment, but im not sure what will be best for my situation really
Jason G
Member #: 1459
En-suite user
Braintree, Essex
What are you planning for the car?
richminiturbo.
Member #: 719
Track day and weekend car mainly!
turbo hogster
Member #: 178
stowmaket suffolk
then go for 31 but no higher than 3.2 this will use the torque curve of the engine better
Milamber what do the metro top out at on the track then with that diff??
m
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Honestly couldn't tell you. 120ish. Thats sreaming it though, well into the 7000+ rpm . Thats with challenge gearset & 13" wheels
assuming 175/50/13's I "calculate" 7k with a 3.9 as 105Mph,
what are the tyres? i'll double check it
richminiturbo.
Member #: 719
How come it would be crap for road use? Because the gears are so close together?
As i wouldnt need to be doing 100+ mph on the road i dont need a taller ratio like a 3.2 or 3.1 surely but you say you run a 3.9 for circuit racing, (obviously its the best for you otherwhise you wouldnt use it) but i thought taller ratios would be best for circuit as youre generally going the highest speed you can and not after the acceleration from a stand still like a purpose built drag engine?
Or is it the perfect combo of acceleration and top end which a 3.9 provides?
it would just be crap because at at 60 in 4th your going to be doing circa 4k rpm which is going to drink petrol and get irritating,
with a 3.44 @60 you'll be doing 3500, which will just take the edge off the "buzz"
with a 3.2, 3250
3.1= 3150
2.9 = 3k
for circuit work you need to find out what top speed your likley to BE ABLE to hit and gear accordingly, ie gear just below this to balance aceleration against top speed.
richminiturbo.
Member #: 719
Yeah true, im almost tempted to stick with a 3.44 just because thats what i already have in there so wont have to buy one.
And thats what originally fitted to the engine so its obviously an all round good ratio otherwise they would have fitted something else as standard!
might be a good option,
as you say it wont cost anything, then you can decide if you want it taller geared or not.
If your not using it on the road tooo much then the 3.44 might be quite good.
With a race car you want to ensure that the engine is constantly running in the power band, therefore you work out how fast you will be going and choose a final drive that will allow you be full on the gas going down there straights, there's no point having power which you're not using.
Where as on a road car you don't really want to be screaming the nuts off your engine when cruising down the motorway, therefore you want to choose a final drive that allows you to cruise along the motorway with out over stressing the engine and wasting fuel.
Basically it's a balancing act in general more revs equal more power equals more fuel being used.
To that extent I've gone totally different directions with my Minis; the British Open has a 2.7 final drive allowing economical stress free motorway driving, whilst I've got a 4.2 to go into the Clubby, I'll be screaming the nuts off it on the straights but there's no point gearing a car to do 150 if the straights aren't long enough to get up to that kind of speed.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Yep thats the size. Rev limiter set at 8000 rpm
And as Rob says...you don't want it screaming constantly down a motorway. Circuits its it up & down.
Edited by Jason G on 20th May, 2008.
richminiturbo.
Member #: 719
Oki doki thanks for the info. I think i'll see what its like with a 3.44 for minute and maybe change it once ive gotten a firm idea of how i want it to behave.
Cheers!
