Home > Help Needed / General Tech Chat > 1982 non mg metro final drive?
welshdan
Member #: 1111
s wales
what final drive is fitted to a 1982 metro, 1275? many thanks
3.44 one does believe
welshdan
Member #: 1111
s wales
cheers. is that a good all rounder? iv got tranx straight cut close ratio gearset, and tranx 1:1 drops. a good combo?
is it for a turbo or normal car?
If normal then yes
if turbo then no, i had this and could hit the limiter in fourth in under a 1/4mile 105mph flat out
go for a 3.2, or less
welshdan
Member #: 1111
s wales
its for a turbo. do some motorway miles though. its a mild turbo car, hoping for 100-120 bhp.ta
2.95 for you then.
welshdan
Member #: 1111
s wales
iv already built the gearbox and diff up again. what qualities does the diff i have give?thanks
none really
welshdan
Member #: 1111
s wales
iv got a few knocking round as part of built up gerarboxes. a metro turbo one, carb 90s mini(non cooper), 1000, mayfair spi. any of these any good?
i think the 1000 may have a 3.1 in it, or maybe a 2.95
the metro turbo will have a 3.2
Id change it now, you'll only regret it if you dont
welshdan
Member #: 1111
s wales
i want a fair bit of top end, as well as acceleration. what does thje diff i already have give?thanks
105mph or so
ive seen 119 from my 3.2 before i got scared (there might of been a bit of over reving with this)
welshdan
Member #: 1111
s wales
i always thought metro turbo fd's were for acceleration, no top end?
No they were to keep the revvs down. Metro Turbos were on the limit of det to keep milage good.
Turbo Tel
Member #: 588
Delaware, USA
I think you may have it the wrong way round.. The lower the FD number the lower the rpm for a given speed. I have just moved from a 3.2 to a 2.95 and its great for a road car, I found even the 3.2 a bit frantic and first gear just spun the wheels.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
We run 3.9's on the racing Metro's, but they made to rev abit higher than normal & quite low boost.. Totally shite for road use.
Again, thanks to mini13 for the calculations. Quite easy to mistake what diffs to run. *wink*
