| Home > Help Needed / General Tech Chat > smoking.... | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
27th Jul, 2004 at 08:43:02pm
every so often usually when sitting in traffic, smoke comes out the back of the bonnet area and sometimes into the car, when i've looked in the engine bay and it seems to be coming from the back of the engine area, maybe the exhaust/turbo joint. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
27th Jul, 2004 at 09:09:08pm
knackered turbo oil seal, knackered stem seals, clogged breathers,
27th Jul, 2004 at 09:12:47pm
the turbo seal and the stem seal had crossed my mind, never thought of the breathers!
9 Posts Member #: 129 Just Registered! |
27th Jul, 2004 at 10:22:08pm
Does this happen while moving? or if you remove the bonnet? Might just be something melting or catching on fire in the engine bay when you're standing on the spot in traffic...
126 Posts Member #: 244 Advanced Member |
28th Jul, 2004 at 06:52:32pm
has the car been stood for a while? If it is a new build and has done alot of stop/start you may have fuel contamination in your oil. Check the dipstick and give it a sniff. Petrol will thin the oil so it will go past the seals easier than fresh oil. Speedster turbo under construction |
28th Jul, 2004 at 08:26:22pm
no, it gets used nearly every day, it only happens every now and then, dont think it happened at all today? weird! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
