| Home > Help Needed / General Tech Chat > wiring up spot lights | |||||||
19th May, 2008 at 08:25:10am
I have wired up four front spot lights which work ok then blow the fuse 15amp. Should use a higer amp fuse or could there be a problem. Thanks |
1 Posts Member #: 2609 Junior Member The 3rd world country known as Yorkshire |
19th May, 2008 at 10:11:16am
Have you wired these up through a relay or have you just wired it straight through a switch?
487 Posts Member #: 1495 Senior Member |
19th May, 2008 at 10:32:40am
meant to use a relay for each light? keeps those electric fires at bay |
1050 Posts Member #: 764 Post Whore Staffordshire |
19th May, 2008 at 10:37:33am
what wattage bulbs are you using? |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
19th May, 2008 at 10:42:42am
i thought it was a relay per set of lights? lol |
19th May, 2008 at 02:35:29pm
i have fed them into the original loom, of which i am unsure if this runs through a relay |
19th May, 2008 at 02:53:57pm
so you basically taken a wire from your main beam wiring (back of the light CLUSTER), too your spotlights??
19th May, 2008 at 03:24:34pm
I suppose yes. I have put a bullet connector in the cluster at the front under were the bonnet sits. |
19th May, 2008 at 03:30:46pm
scrap that!
Edited by Mini_Andy on 19th May, 2008. |
19th May, 2008 at 03:56:53pm
my engine bay will be covered in relays before long. |
857 Posts Member #: 1778 Post Whore Northants |
19th May, 2008 at 04:14:54pm
i just tapped into the existing wiring for full beam/rear fog, ran a wire from there to the relays(1 for each circuit) and then to the lights. i added a fuse box and had a feed from the starter which was then fused and fed the 12v on the relays. not sure what amp fuses i used but i can check later.
19th Jan, 2009 at 09:29:47pm
im crap at this, is this right?
19th Jan, 2009 at 09:44:36pm
I personaly fit a fuse link on the battery terminal on the starter, then wire up to the relay, then a fused supply from the relay to the lamps. That way you are not overloading the fusebox or changing the fuse protection of the circuit.
Edited by Sprocket on 19th Jan, 2009. On 26th Oct, 2004 TurboDave16v said:
19th Jan, 2009 at 10:05:39pm
like this:
19th Jan, 2009 at 10:16:03pm
for reference joey:
19th Jan, 2009 at 10:21:34pm
19th Jan, 2009 at 10:22:38pm
cheers mate, will def come in handy "Turbo's make torque, and torque makes fun"
19th Jan, 2009 at 10:22:58pm
brill, cheers sprock "Turbo's make torque, and torque makes fun"
19th Jan, 2009 at 10:25:18pm
although for one pair of lamps a single 25 fuse link at the starter solenoid will sufice in all situations, as that will protect all the wiring in the event of a dead short on the wiring for the lamps. Maybe its just me, but i am real paranoid about the wiring at such close proximity to the front of the car, a slight nudge on the front end could see a dead short and burn the car out. Thats why Rover fitted fused links to all the later looms On 26th Oct, 2004 TurboDave16v said:
